Technical advice please re: front xantia driveshafts
Gingerposer
x 6
Unread post by Gingerposer »
Before I go posting in the Sales/wants section, I'd like to get a little info please folks.
I have an abs warning light, and have been advised that it is the offside front abs ring, which is cracked. Garage have attempted a repair, but have now advised me to get a replacement driveshaft, as it is this part which is proving impossible to mount the repaired abs ring onto.
Do I need to get a driveshaft from the same model/fuel type/engine size, or are they all the same? Will a second-hand replacement have the abs ring fitted?
My car is a Xantia S2, 1.8 petrol (manual).
Or is there a crafty way of fooling the ecu into thinking the abs is functioning normally and not showing the warning light when it goes for mot in a month?
I should add that the abs warning has been showing since Xmas, however I have normal (non-abs) braking with no funny symptoms.
Regards
Ainslie
acrowot
Unread post by acrowot »
I bought one of these off Ebay, I have not fitted it yet but there is info on how to do it on the Forum, your Garage should not have a problem.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
C5 HDI 110 SX 122000 ESTATE
C5 HDI 2.2 2003 EXCLUSIVE ESTATE 151000 MILES
meexi
Unread post by meexi »
I had to do this to my old Picasso< dead easy to fit put it in an oven for about 5-10 mins have the shaft ready then pop on (remember it will be hot)
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
x 94
Unread post by citronut »
i have in the past welded a split ABS ring then tack welded it back onto the CV joint,
regards malcolm
Gingerposer
x 6
i have just received one from the seller recommended by acrowot - the garage will be having a go at fitting it this coming week, so I will report back how it goes.
Ainslie
