Sorry if this is covered elsewhere, had a quick look round but couldn't see it mentioned?
Rear ARB clamp has broken, well the thin metal rod has corroded and snapped.
Couldn't figure out why the car would only sit high (in jacking pos) or low with no other inbetween positiosn available on the rear.
Initially thought the height corrector mech had seized again or the height corrector itself was blocked, but when I got under car to have a look, I spotted the ARB clamp straight away
MY height corrector is also weeping LHM from one of the diaphragms. I've read that the you can't buy these as a replacement part?
I need to know if the ARB clamp is a 2 piece unit?
I had a quick try to prise the clamp apart but it's pretty corroded. Need a new one anyway.
Anyone been in this situation before?
There's a S/H height corrector on ebay but it's for a MK2. Are they all the same bar the activia??
cheers.
