bleeding hydrolastic system c5
jensen
Unread post by jensen »
HI
have just changed rear seals and gaiters on c5 all new and good going to fill reservoir back up but how do you bleed the system ie bleed nipple on center of back axle
x 94
Unread post by citronut »
hi and welcome
i cant answer your question as i havent had to do this on a C5 as yet,
although it is the BMC's system that was hydro elastic :wink:,
the citroen system is full hydraulic
regards malcolm
AndersDK
Unread post by AndersDK »
The usual method applies, using Citaerobics.
If the LDS container has been drained, the pump needs to be primed by applying a moderate pressure to the vent hole on the containers lid.
Even a bicycle pump may do fine.
Anders (DK) - '90 BX16Image
x 94
hi :wave1: Anders nice to see you poping out of the wood work now and then,
how the hell are you
regards malcolm
