Evening all,
Does anybody know where i might find the EGR valve on a Citroen C3 1.4 Hdi 16v? The car is coming over at the weekend and i'm after a head start
Many thanks in advance
Andy
EGR Location
Andy F
- x 8
EGR Location
1999 Citroen Xantia 2.0 HDi 110 Estate
2001 Citroen Xantia 2.0 HDi 110 LX
1999 Citroen Xsara Picasso 2.0 HDi 90
1983 T25 VW camper
1994 Mini 1275 35th Anniversary Edition - sold
2007 C8 2.0 HDi 136 Exclusive - sold
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
1983 T25 VW camper
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
KevMayer
From the info I have the EGR valve on the 1.4 Hdi is on the exhaust manifold at the gearbox end of the engine.
What are you planning to do to it?
Cheers, Kev
Andy F
- x 8
thanks for the reply,
I'm hoping to remove it and find it all coke'd up then clean it up. What should i use to clean it up with?
Is there anything untoward i should know about?
Much appreciated
Much appreciated
1983 T25 VW camper
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
1983 T25 VW camper
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
KevMayer
If you're removing the EGR valve it would be best to also remove the pipe to the inlet manifold and clean that out.
The best thing to use to clean up an EGR valve is Wynns EGR3 aerosol spray.
You can get it from GSF.
Cheers, Kev
