citroen c4 hdi
1939
citroen c4 hdi
Unread post by 1939 »
hi every one dose any body no the rubber panel that fits the front windscreen the one that fits across the bottom of the screen were the wiper blades are is it suck down with some sort of glue dose any one no what glue to use thanks to any one that would no
kenhall1202
Unread post by kenhall1202 »
This is a perennial early C4 problem which I have experienced first hand ie water and muck getting into the engine compartment via the rubbish sealing arrangement at the windscreen base. The rubber seal simply butts against the lower edge of the glass with clips to hold it in place - no sealant or glue is used. It is very easily dislodged.
For an in depth discussion of the problem I suggest you visit and/or join the C4 forum at http://c4owners.org
Ken Hall
1939
cheers kenhall
