We'll heres a taster of the next project I shall be getting done...
The car has been seen in other places, I think mainly on Club-xm..
However, theres no specific Blog Section on there... and most on here seem to be Xantias.. so I have taken the choice to do it on here.. them prehaps do a copy on Club-xm
Heres some of the best bits:
Work to do:
Replace both strut tops.. the drivers one Has already popped.
Replace bonnet
Replace Drivers wing
Replace rear subframe
Replace exhaust
Wheels and tyres.
Welding... and more welding!
BOTH cills are rather a mess... luckilly the inner cills look ok, and sound ok when tapped with a screw driver head.
I did the head gasket last year while I was using the car, so theres no need to do that again just yet.
Heres the Not so good:
The passenger side is EVEN worse, and is along more of the cill length..
Need to get my welder put back together again now, If I can remember how!
So this girl is to do next.
Other things I want to do:
Upgrade the Air Con from R12 to R134a
Fit Cruise control
For the cruise control, though, Ill have to upgrade the Indicator stalk to S1.5 type, as being a S1 the Lights On main switch is were the cruise stalk will be.. Not sure yet, how much of a Mod will be needed..
So there we are - not to start till I have largly finished the Xantia V6.
Cheers
Paul
