When I connected my Lexia 3 to my Citroen Xantia 2.0 16v make year 2000 I read the following fault: “Display serial supply short to earth or open circuit”.
I saw this error couple of times before and cleared it. Does anyone know the source for this fault ? Can it effect the AL4 behavior ? I also read the AL4 firmwar eversion and got the following:
Supp: 004 Sys: 091 App: 002 Ver: 004 Version: 0305 Download date: 1/1/06
The download date seems weird since the car make year is 2000 and as long as I know the first the AL4 was first introduced in 1998. Anyway is there a newer version for the AL4, can it be downloaded with the Lexia or only othorised dealer can do it ? What is the earliest version that is suitable for the Borg Warner valves ?
Zohar
AL4 fault and firmware version
- My Cars: Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD - x 8
I reconnected my Lexia 3 and I got again the “Display serial supply short to earth or open circuit” and a new one "Gearbox input speed", in spite of the "Gearbox input speed" fault , I don't feel any change in the gear behavior. Is the "Gearbox input speed" a fault should be taken care for ?
Zohar
Zohar
