Hi, While driving my Xantia 1997 td . today , I had a sudden loss of power ,
The accelerator will go straight to the floor with little power . when you get it up to 70 m.p.h. it"s fine and drives ok . could it be the accelerator cable or maybe the turbo ! any help gratfully received
cheers Terry
Xantia loss of power
Xaccers
- x 188
Check the action of the accelerator lever on the pump when someone floors it.
Check all jubilee clips around induction pipes, and also check the rubber pipe that goes to the UFO on top of the fuel pump, that is prone to splitting.
DIY sphere tool
DIY sphere tool
froggy
- (Donor 2026)
- x 4
The Accelerator cable passes through a bracket and into the fuel pump lever . At the bracket there is a metal washer , should there be a spring clip or r clip to hold it in place . What is this missing piece called ? it"s the reason for my loss of power .anyone got any ideas what Iam missing ?
cheers Terry.
cheers Terry.
- x 1240
