My local mechanics have just fitted a new (s/h) steering rack to my 2001 Xsara 90 Hdi. Great except now the airbag light is on and the horn doesn't work. Is there an obvious solution before I go back to them to sort it?
By the way, where is the horn located? It's not obvious!
Xsara Horn & Airbag Light
addo
- Sara Watson's Stalker
- x 95
They've taken the steering wheel off or pushed up on the steering shaft and buggered your clockspring - integral with the headlight/wiper stalks on a facelift Xsara.
Unless a talented mechanic can put yours right (and given progress to date, I doubt they have one to hand), don't muck around with a used piece to replace; insist on a new unit and be sure it is the correct one per your VIN.
phil.s
