On the ZX, there are some square, thick rubber mountings that sit bolted between the body and the bracket that holds the top of the shock absorber.
The mountings on my ZX have split. Haynes doesn't mention how to renew them specifically, but it only mentions them in the section on removing the rear axle, which involves quite a lot of hassle.
Looking at the job, it just seems a case of raising the car up, disconnecting the shock absorbers, unbolting the bracket, sliding in a new mounting and connecting back up.
I was just wondering if someone could confirm what's actually involved in replacing these mountings.
Citroen ZX: Rear Suspension Mountings
- x 1506
Here you go...: ZX Subframe mounts info
Not too bad a job, if the bolts aren't rusted right in... Sorry the pics in my original thread are no longer there, might have them some where if you want them.
- x 94
tjhe rear rear mounts are very easy and you only need to undo the top and bottom securing nuts, then let the tail end of the sub frame hang down and place the new mounts in the lift the rear end back into place and refit the nuts,
the front rear sub frame mounts are a bit harder but not much,
regards malcolm
regards malcolm
geb042
