how do i get my c5 front to sit bit higher?how do i adjust ?
gazzas c5
Hi folks how do i get my c5 front to sit higher up?as i notice other c5s are much higher at the front than mines,how do i adjust it?
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
AndersDK
The smart way to do it is using a Lexia to correct the reference values from the height sensor.
The tedious way is to adjust the position of the clamp on the front antirollbar.
This will require a pit, as you must do it from under the car while it is in normal height with weight on wheels.
Be careful, as even very small adjustment gives large variations in height setting : dont have the clamp dangling loose on the bar.
Anders (DK) - '90 BX16Image
gazzas c5
c5 front height adjustment
how do i get the correct height settings when i use the lexia?thanks
