Is there any way of finding TDC on an automatic, there are no visible reference marks to lock its crankshaft other than the starter ring.
There is a plate with 4 holes where the flywheel would be but these are so far out that that I can feel the valves contacting the pistons when I rotate the pulley.
So how can I go about finding the correct timing position. I am assuming with the cam sprocket and fuel pump sprocket lined up against their respective holes all I need is piston 1 to be at TDC.
I have gone through the this cycle several times but still no way near its correct position,I am obviously missing something and need your help.
Would removing the preignition heaters help, will I be able to feel the piston rising if a coat hanger wire was inserted in its hole even though it seems at 45 degrees to the cylinder. I am tempted to flood the cylinder1 with diesel through the ignition heater hole and observe when it stops oozing out at TDC, then suck out the excess diesel.
Any advice received will be most appreciated.
