hi guys
i had an overheating issue, and i said id take out the thermostat
i took it out, screwed everything back together, and drove on, and noticed that the car dropped in temperature - it went from 90 degrees all the way to 60degrees, and stayed there- as i drove on teh autobahn the whole way.
when i got into the city areas, it heated up a little - to about 70 degrees, and when i went back on the autobahn it went back to 60degrees.
is this ok, or could it do damage to the engine maintaining 60 degrees, rather than 90 degrees, which is overheating territory on a hdi?
i was expecting the removal of the thermostat to cause the car to maintain the operating temp of around 78 degrees to be honest, so this 60 degrees business is strange for me
thanks for your help
ed
overcooling - maintaining 60 degrees - HDI DW10
eurotrotter
HDI
- x 7
That is too low for normal running temperature. Don't forget also that the oil cooler on Hdi's is heat exchanged with the coolant so too low a coolant temp will also lower the oil temp. When winter comes it will run at an even lower temperature. It seems you must have a faulty thermostat so it would be best to replace it with a new one.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 1240
Its about the effect you would expect with no thermostat, when you are driving at above say 30 mph you have a strong current of air through the radiator which slows as you do accounting for the rise in temperature.
If you had been driving it like that in December when we had sub zero temperatures I doubt if the temp gauge needle would have moved off the stop, I know it took about 5 miles for mine to and it has an auxiliary heater.
The purpose of the thermostat is to prevent the water flowing through the radiator until the engine has attained normal working temperature, which an Hdi rarely does in cold temperatures, it doesn't produce enough heat to maintain normal temperature when the heater is on full.
Your experiment has confirmed that the cooling system is OK so a faulty thermostat or temp gauge seem to be the problem.
Chlorate
Looks like putting a new thermostat in would solve your overheating problem then.
If you have your old 'stat and a thermometer handy, you could test it by dropping it in a pan of water on the hob and reading the temperature at which it opens and comparing it to the temperature stamped on it.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
rmunns
- x 9
