Enabling C5 Cruise Control With Lexia
PeteB
Unread post by PeteB »
Hello,
I wonder if anyone can help me. I have a 2003 C5 2.0 HDI Estate and I am trying to add cruise control.
I have bought a stalk and installed it. When checking the ECU in lexia I can see the stalk operating. I have also added the second brake switch which shows up as the redundant switch in the injection ECU, which works fine.
I enabled cruise control in the injection ECU but it does not work. I thought there might be something else to enable but I cannot find it.
Any ideas?
x 1056
Unread post by wheeler »
Set RVV to present in injection ECU & if i remember right there is also a cruise control setting in BSI.
After you have changed the settings disconect lexia & switch the ignition off for 2 minutes to let the settings take effect (a bit like restarting your PC after installing a new program).
wright
Unread post by wright »
the car will need to be in at least 4th gear and 40mph to work, when you press the clutch it will need to be resumed
02 C5 2.0 hdi 110
PeteB
I enabled the option in the engine ecu but I cannot find anything in the BSI. Will it need this enabled to work?
wright
i don't think there is an option in the bsi just the injection ecu
02 C5 2.0 hdi 110
PeteB
I will try it again but I am sure it is not working. What could cause the cruise control not to work?
Pete
