To skim or not to skim?
the jester
Unread post by the jester »
I'm going to replace the cylinder head gasket on my engine,
I'm under the impression the head will near skimmed as a matter of course...
That's an assumption of mine based on ignorance,
Is this the case ?
Or is the head warping not the usual?
How will I know if it needs skimmed or not?
Thanks again
spider
x 77
Unread post by spider »
I would say have it checked to see if its flat (with a straight edge) or you can take it to wherever you were going to get it skimmed and they will check.
Might be worth having it crack tested too.
When I did mine, I took it and left it with them for a crack test and a skim, cost was around £60 (about eight years ago) although not sure if that was a good price or not. I'd taken the cam / buckets + shims out but left the injectors in (just covered the inlets with rubber glove tips and cable ties)
Andy.
x 1240
Unread post by Peter.N. »
There is a lot of work in changing a head gasket, I think it would be false economy not to have it skimmed or at least checked. I would replace the gasket with a steel laminate one if you can get one, they seem much tougher.
the jester
thanks guys
Im going to pull the head off and see whats in there...
there is an excellent machine shop in town, Im in Rallyville so the machine shop has a good reputation 8-)
dieselnutjob
Unread post by dieselnutjob »
it only needs skimming if it isn't flat
get it checked and act accordingly
last time I did a head gasket was maybe 15 years ago on my sisters car.
I polished the head with wire wool and it was so smooth you could see your face in it
It did create quite a bit of dust that needed cleaning up though
it did seal down fine
the car was a 309 1.9 diesel
x 94
Unread post by citronut »
only have as little as possible skimmed, as the more you have removed you will need to have the valves sunck into the seats,
because there is a minimum depth they can be or they will contact the pistons,
also i belive it is as important to slacken/undo the head bolts in the correct order, as it is torquing them down or re/fitting,
just crack each one off in the reverse order for torqueing them down,
so ever decreaseing circle startting at one end,
regards malcolm
