rear leccy windows scenic
deano1970
Unread post by deano1970 »
hi,
my mrs has a 1.6 fidji 03 scenic. the rear electric windows are really dodgy so we don't use them anymore. they come down ok,but it takes an age to get them to go up. The worry is,eventually they won't and we will be stuck with the windows open so like i say, we leave them closed.Will this be a case of the motors both had it? if so, are they easy to replace? and are they expensive? thanks..........dean.......
pug_owner2002
x 3
Unread post by pug_owner2002 »
When you say that "it takes an age to get them to go up", I take it that they are slow?
If so this very similar to a problem I had on my old 306.
The rubber in the window guides had gone hard and was making it difficult for the window to move.
I brought some rubber "revitaliser", removed the door card and sprayed it on the rubber guides and the window operated as normal after that.
R Reg Phase 2 306 DTurbo (Blaze Yellow) (Sold)
X Reg Phase 3 306 1.4 LX (Sold)
03 Renault Scenic Dynamique +
03 Seat Leon 1.9 TDi
52 Nissan Almera 1.8 sport+
deano1970
pug_owner2002 wrote:When you say that "it takes an age to get them to go up", I take it that they are slow?
hi,
thanks for the advice. I will give that a try. to be honest, I have only ever tried it while driving and so am not sure if this is the case. I will try it while the car is still and quiet to make sure the motors are running. If they are, I will try that,thanks. Where would I buy this from? just a car parts shop??
pug_owner2002
x 3
deano1970 wrote:
hi,
I got the stuff from a local motor factors. I imagine if you ask in your local one they may know what it is.
pug_owner2002
x 3
Just had a look on the bay and this Rubber Lubricant is the type of stuff you need. I just searched for "rubber lubricant".
Hope this helps.
