Peugeot 406 2.0 petrol engine
Post Reply
carlo14
My Cars:
Post by carlo14 »
Evening all.
I often see the D9 406 2.0 petrol offered with a 'silver top' engine, and presume this is the later (206 GTI?) engine which they put in around 2000.
Can anyone tell me if this is significantly better than the earlier engine? I find my D8 406 a bit lacking in torque and it'd be nice if the later engine addressed that. Also it seems like it can be chipped a bit, anyone any experience again?
Cheers!
spider
My Cars: Soon, I hope...
x 77
Contact:
Post by spider »
The later ones have the plastic silver tops as you've noticed.
I do not know if they would be a straight swap or not. The GTi 206 one has more power.
The timing belt arrangement is slightly different on the later ones, sometimes the belt came with a compulsory (but no recall) tensioner too.
16valve engines in general do have torque higher up the rev range compared to 8valve engines though.
They 'feel' more eager the later ones but that might be the way they are mapped, not sure. :)
Andy.
ex-vaux
My Cars:
Post by ex-vaux »
My wife's 406 estate has the 2.0 16v engine with the AL4 auto box.
It has just clocked 166500 miles and still runs like a swiss watch! Quite torquey and will pull from low down. Will pick up its skirt and go when required without running out of steam even well into three digits on the speedo!
Get the impression that it is a bit overlooked in favour of the HDI for obvious economy reasons although we get around 33mpg on short trips and around 45mpg on the motorway. Whisper it, but it is probably more reliable than the diesels if not as common!
Nice comfy relaxed drive.
Quite straightforward to work on; no turbo's or intercoolers to fuss over, everything is as you would expect from a relatively modern petrol engined car!
I have read you can tweak it for a few more bhp if required.
I can definately recommend it as a good motor. :)
00 406 2.0 Est GLX auto 166789 miles
95 Xantia SX TD 135660 miles
Triumph Sprint 900
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1206
Post by Peter.N. »
If you want bottom end torque you need to fit a diesel engine :D
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
Peter.N. wrote:If you want bottom end torque you need to fit a diesel engine :D
So - that's what Olivia Newton-John was signing about in Physical, way back when. "Let me hear your bottom torque..."
ex-vaux
My Cars:
Post by ex-vaux »
As I recall, in 'Grease' it did just that...... kept me awake that did! :shock:
Triumph Sprint 900
dieselnutjob
My Cars:
Post by dieselnutjob »
ex-vaux wrote:Whisper it, but it is probably more reliable than the diesels if not as common!
When you get over 200,000 miles on it I'll think about changing my mind.
My Cars: Currently:
x 1206
Post by Peter.N. »
Two of my XMs have done nearly 300,000. 8-)
toh
My Cars:
x 5
Re: Peugeot 406 2.0 petrol engine
Post by toh »
mine also D8 406.
What if turbo kit.?
LOVE is All AROUND.
Post Reply
