Picasso oil filter plunger
Bick
x 44
Unread post by Bick »
Hi all i have a picasso with the cartrage oil filter. 1.6 8v petrol.
when you remove the small paper oil filter there is a plastic plunger and spring that it fits on.
well its broken! good that oil and plastic!
citroen say i have to purchase the whole oil filter housing just to get the plunger. they say only the filter and cap can be purchased seperatly.
this is bad because they are £106 and all i need is the plastic plunger :(
do any of you know where i can get one from
many thanks
polar
x 94
Unread post by citronut »
if you post the last 8 digits of you chassis/VIN No. i will look on service citroen to see exactly what is avalible, and price
regards malcolm
Bick
x 44
citronut wrote:if you post the last 8 digits of you chassis/VIN No. i will look on service Citroën to see exactly what is avalible, and price
regards malcolm
thanks malcolm, the number is 39813248.
thanks again
bick
Deanxm
x 87
Unread post by Deanxm »
if this is the case and they are not available then its got to be a breakers really, its the only place i think you are going to get one and for very little money.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
x 94
the filter houseing is
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00001103P3 FILTER BRACKET 97.95 GBP 117.54 GBP 117.54 GBP
but the picy of the filter looks like its got something through the centre, this might be the plundger,
here is price and part No. of two filters listed for your chassis No.
00001109CK OIL FILTER 11.22 GBP 13.46 GBP 13.46 GBP
E149109 OIL FILTER 6.71 GBP 7.88 GBP 7.88 GBP,
might be worth asking if your local dealer can show you both opptions,
regards malcolm
AndersDK
Unread post by AndersDK »
The same filter housing and cartrigde are used on all later TU type engines, and most 2.0HDI's
The spring would press the filter cartridge against the bottom of the housing and the plunger is there to keep the spring located - I suppose ?
Would the spring together with the cartridge bottom seal constitute the filter bypass valve ?
Anders (DK) - '90 BX16Image
Bick
x 44
A big thank you malcolm, i will be on the case tuesday. will let you all know how i get on.
AndersDk i thing you are correct with the bypass valve idea.
kind regards
bick
Bick
x 44
Just an update.
you cannot get the plunger seperate from the oil filter housing, funny as Haynes says it should be changed every time you do an oil change. :lol:
so at the moment ive done a bit of a bodge and its okay.
if you do do an oil change with this type of filter,you must pull the plunger up to empty the filter housing but take care.
i do miss my very simple, reliable xantia :oops:
thanks folks
bick
