xantia rear suspension leak
reservex
Unread post by reservex »
I have a leak on the rear suspension, it appears to be coming from a plastic pipe on the nearside under the sub frame, is this a low pressure return pipe? any one with any experience of this?
1999 Xantia Estate 1.9TD
rory_perrett
Unread post by rory_perrett »
If it is plastic pipe then it will be low pressure. There are two plastic pipes which are a "push" fit into the rubber gaiter on the rear cylinder.
x 94
Unread post by citronut »
the two pipes at the gaitor one is a greather and the other is a seapage return which collects any citro blood that seaps past the suspension unit high presure seals, then returns to the tank under capillery action,
regards malcolm
reservex
Thanks guys, pulled the pipe out at both ends and found a split, repaired same many thanks
