Where should I satrt?
About a year and a half ago was the last service! [:I]
looking to change Glowplugs, filters and oil.....hoping glowplug may cure rough starting!
Any thing else I should change?[?][?][?]
Where to start the service?
airfilter is a must!! on a car of that age the air filter will need changing quite often, you'll notice a huge difference. If you know how long since the diesel filter was changed you can probably avoid changing it.
If its been non serviced for a long time then its probably a good idea to flush the coolant system out completely
...tokk the air filter out last weekend and gave it a good bannging, covered the wife's car in all sorts ! [:D].
OK comments taken on board, but is they a systamatic approach I should take in doing the service, it may be spread out over several weekends....time/money constaints.
Once again thanks all
- Contact:
Assuming we're talking front hoses then it's simply a case of swapping them over when you drain and refill the LHM. Easiest to do it then, as if you're doing a thorough job you'd need to bleed the brakes anyway.
Rears can be a bit more tricky to bleed - but again, if you're being thorough you'll need to do this also with a fluid change. You need to get some weight on the back end as the rear brake pressure depends on load and is fed from the suspension circuit.
Follow the Haynes procedure with that in mind and you should be OK.
Adrian
Adrian
Hello folks,
I can thoroughly recommend changing the LHM fluid and cleaning the filters and inside of reservoir; i did it to my dad's Xantia last weekend as i had to fit a new accumulator sphere anyway. The old one was a re-con sphere and it had been on the car for 4 years!! Needless to say, it was shafted!![xx(] Regulator clicking every three seconds, aaarrrggghhh!!!!! It was worth doing the job anyway; at idle it clicks every 3 to 4 minutes now and it no longer drops down onto the bump stops from a cold start.[:D][^] Ride quality and feel of brakes are much improved too, especially as i changed the rear anti sink sphere a couple of months back too. The car is a '94 M plate and has covered 112,000 miles, and judging by the state of the filters i don't think they have ever been cleaned and treated to a fluid change in the cars life. I do love working on Hydro-Cits!![:D][^]
Cheers, Rich.
Xantia Exclusive HDi.
Cheers, Rich.
Hello again!
Forgot to say, going back to what Adrian said about bleeding the brakes; i also did that, but i did it as described in the Haynes manual with the suspension on it's highest setting with no problems. Just gets any old fluid/air out of the brakes as they are "dead ends" in the system.[^]
Cheers, Rich.
Cheers, Rich.
