XANTIA - reset warning lights, ABS fault
willhay33
Unread post by willhay33 »
Xantia 2.0 HDi Diesel
I recentley had the ABS warnig light come on and checked the circuit to find the right rear wheel was the problem (using a resistance meter), i believe i have fixed the problem/sensor fault, however the warning light is still on. Is there a way to reset this without using a Lexia/computer, or does it mean i have not fixed the problem.
Thanks,
Will
DHallworth
x 167
Unread post by DHallworth »
If you take the car for a drive, once you go over i think it's 20mph the light will go off as long as it's getting a reading from all 4 sensors that matches.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
