Help
I have an 'N' reg xantia 2.0 16v SX. The heater lower has recently started playing up. Innitially there was a hot smell like burning wires but no noise and the blower went off. No fuses blown. Since then it comes on every so often (once every two - three days) for no reason, smells hot and goes off. I can't seem to get to it to check wires etc. Can anyone help.? Is it a common problem? How easy is it to remove the blower?
thanks
nick
xantia heater motor help
If memory serves me correct, to gain access to the blower motor you have to remove the glove box, which is held in place by 5 torx screws, remembering to disconnect the lamp before you fully remove it.
The motor is located behind the glove box, to the lhs up the top, it’s held in place by 3 torx screws again, remembering to disconnect the wires to the motor.
Dom
Dom
