What Bolt am I Missing???
gadgetgricey
Unread post by gadgetgricey »
Got to move my 2.1TD breaker as the wife wants the garden back. (Selfish of her I know :oops: )
Trying to take bits off it today, and have got stuck on the following.
I think its the Diesel pump, (But knowing my skills it could be the ABS unit :lol: :lol: )
I''ve disconnected all the pipework, and also removed the three bolts. It moved slightly but wont come off. Now even taken the big bolt of the cam belt gubbins on the left with no success.
It jiggles around in all directions, but wont come off.
Any ideas????
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
Chris570
x 36
Unread post by Chris570 »
so you've got the 3 13mm nuts off the pump housing?
i'd get the sprocket off as if you're removing it that way it needs to be removed
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
steelcityuk
Unread post by steelcityuk »
I'd say the pulley would have to come off.
Steve.
not applicable
Xaccers
x 188
Unread post by Xaccers »
Yup, and you'll need to make up/buy a pulley puller :)
Don't loose the woodruff key!
DIY sphere tool
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Theres another 3rd 13mm nut HIDDEN down the bottom behind the Spring looking tensioner... you WILL have to get that bracket off to get at the 13mm nut on the pump...
to get that off, HP pump off, altinator off, then theres 3 6mm allen head bolts and a 13mm bolt and the bracket comes off...
Paul
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
Dave, they may also be a 4th nut on the END of the pump body.. Im not familliar with the Lucas epic pump mounting but there is on the Bosch pumps...
Paul
A very sad...
1994 XM 2.1 d auto
x 8462
citroenxm wrote:Dave, they may also be a 4th nut on the END of the pump body.. Im not familliar with the Lucas epic pump mounting but there is on the Bosch pumps...
Paul
Yes, it's the same as a Bosch Paul, three nuts on the flange (one inaccessible) and one on the end...
A 'half moon' spanner helps with the inaccessible one...
You'll need a puller like this to get the sprocket off:
