turbo wastegate solenoid location
johntom
Unread post by johntom »
Hi
my 2002 van dispatch (with a 2.0 hdi engine) as a po243 fault code turbo/sup wastegate solenoid A malfunction which of the 3 identical solenoids is the wastegate one ?
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
try locating the Wastegate Vaccumm pipe and follow it to the valve...
Paul
A very sad...
1994 XM 2.1 d auto
johntom
Hi
I had a quick look and the 2 leftmost solenoids (egr and another ?) had a common vacuum pipe going to their 'in' ports. When i followed the pipe to the 3rd solenoid (on the rhs) the pipe sucking on tickover was going to the 'out' port ?
surely the vacuum's should all be at the solenoid 'in's which then opens to allow the vacuum to reach the valves (wastegate, egr etc) ?
could someone in the know confirm or put me straight ?
citroenxm
Fallen Hero
x 70
The pipes are in a constant vaccumm.. The solinoid valves then open and close depending when the ecu will call for either turbo wastegate to open. Egr valve to open...i think the third opens a supplementry inlet butterfly at some point..
Paul
A very sad...
1994 XM 2.1 d auto
johntom
thanks, so should all three solenoids have the pipe with the vacuum at tickover going to the 'in' port ?
cachaciero
x 9
Unread post by cachaciero »
johntom wrote:thanks, so should all three solenoids have the pipe with the vacuum at tickover going to the 'in' port ?
Don't know but as the valve is only a two port on or off device wouldn't have thought it would make much difference.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
