Siemens or Bosch? How to tell on a Xantia
nobbi1977
Unread post by nobbi1977 »
I have a 99 Xantia HDI 90 and have just got hold of a DTUK box very cheap.
The box is for a Siemens fuel system HDI but I have no idea how to check which system is in my car. :oops:
Xantia HDI 90 1999 (Free, Thanks Dad)
Renault Grand Scenic 1.9 DCI
Renault 5 Campus (Free,Took it to the scrap yard)
Peugeot 405 SRI (I loved that car!!)
Peugeot 405 1.6 (The boat)
Peugeot 309 (My first frenchy)
spider
x 77
Unread post by spider »
Is it not stamped on the high pressure pump (or ECU) who manufactured it ? :?:
Its been a few years since I looked at one so not 100% sure.
Andy.
nobbi1977
spider wrote:Is it not stamped on the high pressure pump (or ECU) who manufactured it ? :?:
No idea. I open the bonnet and just see the huge black cover. Guess I better do a bit of digging. I did not know if there was a quick check method
x 1476
Bosch has an in-tank electric pump, which you should be able to hear running for approx 10s after ignition switch on (if you don't crank it!) - Siemens doesn't, and has an underbonnet fuel primer.
FWIW I'm pretty sure that ALL Xantias are Bosch - Siemens only came along later in Xsaras etc.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi Richard..
So why doesn't Siemans have a Lift pump?? Is there a Draw Pump built into the Engine Pump??
The Lift pumps in the Xantias constantly run after the engine has started just like a petrol engine..
As for the Q.. Remove the cover from the engine, by twisting the 4 black "Button Clips", watch the rear as there could be some Vaccum hoses attached... then you will see the pump on the engine.. on it it should have Bosch and the Part number..
So far EVERY Xantia 90 or 110bhp use the Bosch setup..
Paul
A very sad...
1994 XM 2.1 d auto
x 1055
Unread post by wheeler »
citroenxm wrote:So why doesn't Siemans have a Lift pump?? Is there a Draw Pump built into the Engine Pump??
Yes thats correct, the lift pump is built into the main hp pump.
If its a xantia HDi then its bosch, siemens was never fitted to the xantia.
