C5 rear axle bushes
Allanxantia
C5 rear axle bushes
Has anyone had to replace these, getting a bit of noise from the back over bumps, checked the trailing arm bearings which seem absolutely fine, but seems to be quite a bit of flex in the bushes.
2002 C5 V6 Exclusive auto LPG
1997 Xantia TD SX £200 bargain
1993 Xantia DLX (now dead)
Then after a 10 year Citroenless gap
1995N Xantia Activa
1995N Xantia Activa
alden
c5 bushes
have a look on the swinging arm,there should be a rubber pointing upwards either side that travel up on the arm. mine had one missing when I got a knockin noise over speed bumps.dead simple job, they just pop out and replace with new ones, not expensive either. I cant check proper as I sold my c5 with gritted teeth as we needed more seats and went for the c8 (c5 best car i ever had)
BX 19 TRS
C5 SX EST 2.2
C8 2.0 SX
C5 SX EST 2.2
C8 2.0 SX
