Are there after market rear suspension cylinders ? Can a faulty rear cylinder be fixed ?
Thank
Zohar
Xantia rear suspension cylinders
lancia58
- x 8
AndersDK
Personally I have never seen aftermarket parts for Citroen hydraulic components - except the gas spheres.
They are er too special and slow selling.
Your best chance is a breaker or private seller.
If they leak from a defective seal, the seal can in fact be replaced, but then you MUST correct the cause of the defective seal, i.e. polishing the piston.
And the piston must positively NOT be pitted - at all.
Anders (DK) - '90 BX16Image
lancia58
- x 8
AndersDK
Remove the clamp that holds the rubber bellow on to the cylinder.
Then pull off the bellow.
Note the felt washer.
With 2 fingers inside the hollow piston draw the piston out from the cylinder.
Take care not to drop it or scratch it.
Inside the cylinder you can see and feel the seals.
The outermost seal is the dust seal, the innermost seal is the piston seal.
Its exactly the same construction as a brake caliper.
The seals comes in different diameters - according to the internal diameter of the cylinder.
There are different cylinder sizes according to year model of your Xantia, therefore you must first know the cylinder diameter.
Clean the piston, then polish it using standard steel polishing methods.
Before assembly, clean all parts and lubricate with fresh LHM.
SwissSPEC
Slight hijack of this thread, anyone know where some cheap xantia saloon non hydractive cylinders can be purchased from, i need some for a bx as those one's are stupid prices. I'm aware that they aren't a direct fit & require modding, but thats not a problem. I'd prefer new if poss, but if good condition 2nd hand ones are lurking about then i'd be interested if anyone has any spares that they don't need?
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
Bx Gti 16v
BX TZD Turbo - Sorn
lancia58
- x 8
Hi Anders
Thanks for the detailed instructions , is a fine sand paper can be used to polish the piston ? The sealing you mention is an O-ring like ? Is the thickness of the sealing of an importance ?
Are these sealings sold by Citroen or you can find them in any hardware store ?
Citroen part number for the rear cylinders are:
Right: 5272 53
Left: 5272 54
Zohar
Right: 5272 53
Left: 5272 54
Zohar
AndersDK
You need one of these - for each cylinder :
5272.18 O-RING seal DIAM 37,3 EP3,6 - xantia since OPR 06779 & C5 SEDAN
5272.29 seal DIAM 37 EP3 - xantia since OPR 06779 & C5 SEDAN
5272.31 seal DIAM 38X44 EP2,4 - xantia since OPR 06779 & C5 SEDAN
The seals are special and only Citroen can supply them.
Polishing the piston must be done with care using very fine emery paper Grit 600 or higher.
Finish off using polishing paste like your grandma uses for silver and brass household.
lancia58
- x 8
Xaccers
- x 188
Yes you can reuse the spheres.
You have to remove them before you can remove the cylinder.
Have you confirmed that one of them is leaking?
DIY sphere tool
DIY sphere tool
lancia58
- x 8
No I still hadn’t but I am going to do that , it locks logical that this is the case since the rear suspension is sinking immediately after stopping the engine and no resistance when pushing it downwards. The main accumulator is 10 month old and before replacing it was ticking. I replaced all the rear three spheres and the middle one manufacturing year was 2004, it may be that it was defective I don’t know for sure but it looks that a shelf life of 7 years it too long. Anyway I’ll start with checking the cylinders, once I’ll do that I’ll post the results.
Thanks a lot
Zohar
Thanks a lot
Zohar
hanskj
Hi
It could also be the rear antisinkvalve or the brakevalve/Doseur thats leaky
Here´s a guide on how to fix the doseur.
http://www.bxclub.co.uk/forum/viewtopic.php?t=6351
Citroen C5 Tourer 3.0 V6 HDI 240 2009
lancia58
- x 8
lancia58
- x 8
AndersDK
hanskj
