The BoL says that it should be F7 but the board layout shown does not look at all like the one in the car. F7 is OK. The front socket seems to have no power. I haven't noticed that anything else is not working.
Any thoughts?
What fuse does the front 12v Socket? Mk II C5 Estate.
Philjw
Phil
05 C5 Estate 2.0 16v + 05 C4 Hatchback 2.0 16V
AndersDK
Philjw
addo
- Sara Watson's Stalker
- x 95
Philjw
AndersDK
Philjw
Hi Anders,
That seems to be the handbook for the current model. On mine which is the first facelift the cigar lighter is OK but both the 12v sockets are out. I think that the mk 1 had the two sockets powered from 1 fuse (f7) and the cigar lighter from another.
Phil
AndersDK
Philjw
MikeT
- x 232
Philjw
Solved!
Well as we couldn't say which fuse to look at I resorted to checking every fuse in sight. It turns out to be one of the larger size fuses in the glove box. There are just 3, 2 x 30 amp and one x 20 amp. It is the 30A one in the middle. You need a meter to tell it is blown as unlike the smaller fuses you can't see the conductor.
Thanks to all who contributed.
Phil
