Xantia Door cards
robert_e_smart
x 14
Xantia Door cards
Unread post by robert_e_smart »
Morning Folks,
Just a quick one, can series 1 Xantia door cards be fitted to a series 2 car? If so what modifications need to be made.
From what I can tell the door armrest screws are in different locations.
Robert
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
x 8386
As far as I know, no Robert, you can't (easily)...
Mind you, I can see why you would want to, S1 door cards are far superior to SII items....
< runs and hides>
Xantia Colin
Unread post by Xantia Colin »
CitroJim wrote:I can see why you would want to, S1 door cards are far superior to SII items....
:? I can't see why you would want a SII to put your S1 door cards into...
1996 Xantia 1.9td Estate
1994 Xantia 2.0 16v VSX Sinker
1993 Xantia 1.8 Sinker
1993 Xantia 1.9td Sinker
1996 Xantia Activa
mongoose100
Unread post by mongoose100 »
Speaking of door cards...
Can the S1 window switches go into the S2's? Love the 'one touch' auto feature as opposed to the 'hold to activate' system
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
Xaccers
x 188
Unread post by Xaccers »
mongoose100 wrote:Speaking of door cards...
That's a spec level thing rather than S1/S2
SX/VSX/Activa have one touch driver's switch (not sure about LX).
Paul's S2 exclusive has all round one touch.
DIY sphere tool
mongoose100
Yes, thats true, however my S1 is a quick press to enable auto, whereas the S2 is push and hold for 2 seconds to enable that feature
Regan.
2001 Citroën C5 V6
Citroenmad
x 110
Unread post by Citroenmad »
No, I dont think the LX Xantia has one touch on the drivers window.
Xac wrote: Paul's S2 exclusive has all round one touch.
I think every C5 has one touch on all windows.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Xaccers
x 188
Interesting, all of mine (S1 and S2) you have to hold it for a second or so before it activates the one touch. Just tapping the switch makes it jump up a little bit only.
DIY sphere tool
mongoose100
Xac wrote: Interesting, all of mine (S1 and S2) you have to hold it for a second or so before it activates the one touch. Just tapping the switch makes it jump up a little bit only.
Hmmm, what year are yours?
My S1's are 93 & 94
Regan.
2001 Citroën C5 V6
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
They swapped the one touch format around laye 96....from press to activate to press and hold for two seconds to activate.... This im sure will be the programe in the drivers door black box behind the door card... Its not the switch... They are all identical right across board...
Every xantia with elec windows had one touch on the.drivers door.. Even lx.. But only s2 cars added anti pinch... Which renderes s1 drivers windows not compatible with s2 cars though the rest will be except in exclusive were all are one touch and anti pinch...
As for door cards... The switchs have their own house which is the same again acrocc board.. The only thing you have to do is drill a new tiny hole for the screw nearest the end of the door to screw in... The other two ie the middle one and upper one by the switches are in the same place... I have to say s2 cards are far supeiour making wonderfull use of the other wise wasted gap between the arm rest and lower door pocket.. A great hidey hole... And its not small either..
Paul
A very sad...
1994 XM 2.1 d auto
robert_e_smart
x 14
Ok,
So move the plastic threaded chaps from the series 1 door into the series 2 for the armrest to screw into, and drill a new hole to screw the door card on at the speaker end?? Or the other end?
1991 BX 16 TGS Auto
citroenxm
Fallen Hero
x 70
No robert... Leave them.. Just drill a 4mm hole at the end so the screw will self tap and tighten into it... Thats all... Im sure the other one lines up ok...
A very sad...
1994 XM 2.1 d auto
