C5 front suspension very low and scrapes underneath on drive
gazzas c5
Hi folks,my c5 front suspension is low and i cant get it on my drive any more due to the front underside banging off the driveway,I had a c5 before and had no problems with it,somehow this one is low at the front normal height and the suspension goes up and down ok using the button,Its doing my head in as have to park it on the road as cant get it on drive without it scrapping underneath,How do i solve this problem?thanks Gary
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
timborob
Re: C5 front suspension very low and scrapes underneath on d
Hi Garygazzas c5 wrote:Hi folks,my c5 front suspension is low and i cant get it on my drive any more due to the front underside banging off the driveway,I had a c5 before and had no problems with it,somehow this one is low at the front normal height and the suspension goes up and down ok using the button,Its doing my head in as have to park it on the road as cant get it on drive without it scrapping underneath,How do i solve this problem?thanks Gary
I would suggest starting checking/ further investigation with someone with a Lexia to check for code errors
Here's a list of lexia owners from the supersticky page who will be able to help
http://www.frenchcarforum.co.uk/forum/v ... hp?t=29178
Good Luck in getting the fault found and fixed.
Regards
Tim
03 Citroen C5 2.0 110 HDI VTR Mauritius Blue 109K
Tim
AndersDK
Your dealer can easily fix this problem by correcting the height setting values via his Lexia tester.
- or by correcting any mechanical problem with the height sensor.
A new height sensor is only some £60 and would not take more than 1 hour to install and adjust.
They are electric sensors these days on a C5
Anders (DK) - '90 BX16Image
dnsey
- x 19
Citroenmad
- x 110
It does sound like a problem relating tot he front height corrector. Has your C5 always been as low as it is or is it a recent problem?
If the suspension moves into intermediate and high, can you not use those settings to get the car onto your drive until the problem is fixed?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
dnsey
- x 19
gazzas c5
C5 FRONT SUSPENSION LOW AND BUMPY
Hi folks,no its just happened recently ,I am taking it to get a lexia plugged in at one of my Renault friends ,but not sure if the laptop will pick up the fault,am pretty sure its the height adjuster,horrible driving it at the minute like that,cant wait to get it sorted!!!
Homer
- x 16
Re: C5 FRONT SUSPENSION LOW AND BUMPY
Dangerous and probably damaging to the car I would say!gazzas c5 wrote:horrible driving it at the minute like that,
AndersDK
There is no such adjuster on your C5.gazzas c5 wrote:...,am pretty sure its the height adjuster,....
It's a sensor.
It signals back the actual height to the hydraulic pressure unit.
It works just the same as a throttle potientiometer.
5273.J4 Vertical sensor
Its the same type both front & rear to all C5 hydro series and the C6 series.
Over here at my end of the Eastbound winds the pricetag is equivalent to approx £34 ex.vat.
Downright cheap
gazzas c5
c5 suspension hard and low where is the sensor
Hi folks where is the c5 suspension sensor abouts?cheers
