- been a while since I was around last time.
A question has popped up and developed to be a PITA
On a camshaft in a standard TU / XU engine, you have the bearing blocks to locate the camshaft while running.
Digging in the Haynes manuals for the various late '80 and 90 models with the popular TU engine family, there is no torque setting given for the bolts for these bearing blocks.
Only setting you can find is the "camshaft thrust fork retaining bolt" torque setting, which is given as 16Nm.
Is this the answer to my question ?
It seems a bit on the low side using this torque setting for an axle bearing block.
Thanks in advance.
