2.1 Cooling System Diagram/Photo
steelcityuk
Unread post by steelcityuk »
Due to the long lay-up in the rebuilding of my 2.1 I can't find the photos I'd taken of the pipework for the cooling system. If anyone could post a couple or a link that would be most helpful. The main areas of interest are the links from the head outlet behind the injector pump, the connections on the Bosch injection pump, the oil/water heat exchanger and the main head outlet stem.
In the meantime I'll keep searching.
Thanks in advance.
Steve.
not applicable
Geoff Lebowski
Unread post by Geoff Lebowski »
Hope the following helps. I have some Bosch cold advance coolant hoses and cylinder hear spigot available if you need them, but they are based on a BX! The spigot and the feed from it to the Bosch cold advance should be the same, not sure about the the other pipe connected to the cold advance.
Both dwgs based a MK 1 XM 2.1 TD Auto
I'm also scrapping a mk 2 2.1 TD Auto with Epic, so if any parts transfer then I can hopefully help out
steelcityuk
Thanks Geoff, that's just what I needed.
Steve.
not applicable
