Citroen Independent Warrington Area?
chrisall
Unread post by chrisall »
Hi, been lurking a while and time for my first post! I have just bought a cheap 2005 C5 1.8 (facelift model) and need to get the clutch changed pretty soon as it judders badly when setting off.
It was a trade sale off ebay and I bought it cheap enough, so just got to take the hit. I've done a bit of googling and it seems like a common problem on the C5. I'm looking for a reliable Citroen independent specialist in the Warrington area to fit a new one and replace the rear crank seal at the same time - any recommendations from members of the board that have had work done?
I will most likely supply the clutch as there seems some pretty good ebay bargains for decent makes such as motaquip, unless anybody can also recommend a cheap supplier of parts too?
Cheers,
Chrisall
KP
x 27
Unread post by KP »
Nearest one I have used and can recommend is Paris autos in Stockport. Usually got a few copies of ccc knocking about and I'm sure if you ask nice can drop off and pick up from the station a few miles away.
timborob
Unread post by timborob »
Welcome to the Forum chrisall
I too browse alot on here and there's some great Advice and Knowledge on here.
Regards
Tim
03 Citroen C5 2.0 110 HDI VTR Mauritius Blue 109K
x 94
Unread post by citronut »
hi and welcome
just be carefull of CHEAP as they might not always be what they seem,
and its a lot of work to be doing it again shortly,
regards malcolm
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
Firstly, :welc:
Secondly, I'll have a chat to the taxi driver's this afternoon when I get into work, there are usually 3 or 4 on the rank with C5's.
Thirdly, I know of one in Southport and one in Blackpool, if you get really stuck :roll:
Steve
http://c6owners.org/index.php
Trainman
(Donor 2018)
x 43
Try these guy's, I'm not sure what they are like as I've never used them
http://www.buyyourcar.co.uk/directory/c ... list_38014
Steve
