berlingo 1.9d van horn
dave28
Hi all my horn on the van has decided to stop working and i cannot seem to find where it is located so i can check the connections .So can anyone help me out by telling me the location of it.
many thanks
- x 1061
dave28
- x 1061
In that case i'd be pretty certain that it's a berlingo 2 & that the wiring from the com2000 (indicator & wiper stalk assembly) is shorting on the steering column, you need to get this sorted asap or it will burn out the com2000 & they aint cheap. Just follow the wiring up from the column & insulate & re route the wiring away from the moving part of the column.dave28 wrote:thanks for the reply about the location but have now noticed that the horn works ok without the ignition on but nothing when it is turned on.
