Hi,m y 1997 Xantia td. When I start up, [ cold or warm] the engine fails to pickup for about a second or two , but when it does I get a large plume of smoke . The engine runs smoothly though . any ideas ?
cheers Terry
Xantia Starting
Xaccers
- x 186
Glow plugs or air ingress.
DIY sphere tool
DIY sphere tool
spider
- x 77
My thoughts too.
Ingress is probably a bit more likely if it happens when its warm.
Try squeezing the primer bulb three or four times, then try to start it to see if there's any improvement, this does not always determine the cause but its a quick and easy test.
Andy.
Xaccers
- x 186
Possible air ingress points:
Leak off pipes between injectors, if they're hard replace them anyway.
Primer bulb
Pipe between bulb and fuel filter housing
O-ring between the base of the housing and heat exchanger
Housing thermostat
Housing lid
Elbow piece from lid towards pump.
Size adaptor between lid and pump.
Replace as much fuel line from the primer to the pump as you can with clear silicon tube to check for air.
Primer bulb
Housing thermostat
Housing lid
DIY sphere tool
DIY sphere tool
