AX Lower Wishbone front bush
fred1
Unread post by fred1 »
Anyone have experience of replacing the front bushes on an AX lower front wishbone?
Is it the same !!**!! of a job as on the Xantia?
Regards
John
Chris570
x 36
Unread post by Chris570 »
buy a new arm.
its more cost effective as you'll get the balljoint and rear bush.
if your ax is mk2 (roughly 91 onwards) then you can use the saxo wishbones of the equiv type (if your ax has an ARB mounted to the wishbone you have to get the lower specced saxo ones, and you have no ARB or a GTi then you can go for the VTR/S ones)
It is possible to get the bush out but you need lots of heat and violence
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
