1.9TD Xantia estate tyres on alloys
Xaccers
x 188
Unread post by Xaccers »
On steels, Cassy runs 185/65/R15H, but now I've got a set of alloys, they're similar to the activa ones, Jenny has the same fitted.
To my knowledge they still take 205/60/R15's, and that's what's currently fitted, but what speed rating is needed?
Juliet uses V/W, but then she's an Activa.
DIY sphere tool
Chris570
x 36
Unread post by Chris570 »
i'd just go for whatever is on there now i doubt the speed rating will be diff between the 2.1td and 1.9td
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
Xaccers
x 188
superloopy1 wrote:My 1.9td runs on H rated michelins, should do the job ok.
Are they on alloys or steels?
DIY sphere tool
handyman
Unread post by handyman »
Hi Xac, all the lower spec Xantias should be run on H rated tyres, with a minimum load factor of 88 (?). The codes should be seen as a reflection on the handling of the car, not its potential top speed. :shock:
I seem to remember all alloy wheels being fitted with 205/60R15 tyres, as they are wider than the steels and a 185/65R15 tyre is on its limits on a wider rim.
I'm in the workshop tomorrow, tyre changing, so I'll confirm this is correct.
Handyman
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
handyman wrote:I seem to remember all alloy wheels being fitted with 205/60R15 tyres, as they are wider than the steels and a 185/65R15 tyre is on its limits on a wider rim.
My VSX has its original alloys which use 185/65/15 88H tyres.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
addo
Sara Watson's Stalker
x 95
Unread post by addo »
There are two widths of alloys; VSX/Activa/Exclusive use a 6J while the SX and similar have a 5½J.
Offsets are different, too. A mismatched axle pair could be interesting for cornering effects, as it would mess up the Ackermann geometry.
