xsara 1 airbag light is back flashing on and off again!
eurotrotter
Unread post by eurotrotter »
hello hello hello
hope everyone is doing well
about 2 months ago my airbag light was flashing, cloggz recommended for me to d/c and reconnect the battery, i did it and it stopped the airbag light from flashing - thanks again cloggz worked a treat
but now, about 2 months later the light decides to come back on again, and is flashing again, i d/c and reconnected the battery again, hope it work again, but this time, it did nothing.
any ideas?
thanks very much
p.s i dont have multiplexing
ed
spider
x 77
Unread post by spider »
Might need it resetting properly with a Lexia.
Disconnect battery (important) and wait a couple of minutes.
Examine the wiring under the front seats that are connected to the pre-tensioners. It's likely this is where the problem is, as its the most common failure point.
Andy.
eurotrotter
i will try waiting a couple of mins so b4 reconnecting the next time i try.
its the AIRBAG light, not the side airbag symbol, so could it still be wiring under the seat?
thanks guys
ed
spider
x 77
Yes, I was not aware you had side airbags on a MK1 ? :?:
I was assuming it was doing the "306" / "ZX" thing and wiring under the seats was breaking. :) , I guess they could be in the seat belts / pillar instead but I am not sure. Just trying to provide a few pointers for the moment to assist, hopefully.
spider wrote: Examine the wiring under the front seats that are connected to the pre-tensioners. It's likely this is where the problem is, as its the most common failure point.
Remember to disconnect battery first, wait a few minutes (leave battery off!) and then go look at the wiring. On a 306 it was not uncommon to chop the plug off and solder / heat-shrink the wiring to stop it re-occurring.
Andy.
eurotrotter
my machine has side airbags:
https://picasaweb.google.com/edmondkelleher/Xsara#
it was build in april 2000
i will just try d/c and reconnecting the connections for teh airbags under the seats for now after d/c the battery
thanks guys!!
