hi,
I have a 2002 C5, recently when I step into reverse, I can not hear the usual beep. I checked and found that the reverse lights do not light up, and the parking sensors were not working.
A few days later the beep went back to work, and with it the lights and sensors. I mean, it comes and goes.
What problem do you think? Is it a touch loose in the handle?
c5 reverse switch fault or not?
Onlinemyglaren
- x 5688
alden
reverse lights
possibly the switch on gearbox , cant tell you where it is as ive not got my c5 anymore but my bet its on or around gearbox, once you locate it take it out and wd40 it and put it back... i had same fault on a car and this was how it was sorted ,, got to be worth a go
BX 19 TRS
C5 SX EST 2.2
C8 2.0 SX
C5 SX EST 2.2
C8 2.0 SX
Onlinemyglaren
- x 5688
Pleiades
adel
Onlinemyglaren
- x 5688
adel
Re: c5 reverse switch fault or not?
we tried to change the switch, but it didn't help! any idea please?
some one does know from where the reverse light get the order to light on?
Citroenmad
- x 110
Re:
I also had the exact same problems on my 04 C4, it cured itself!myglaren wrote:I had exactly the same symptoms and a new reversing light switch cured it.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
adel
any one??!!
maybe someone have the Schema of the c5 2002 sx Electricity?
Onlinemyglaren
- x 5688
Re:
Have you tried Martin's suggestion, simplest method of determining if the fault is with the switch or elsewhere.
Pleiades wrote:Easy to test.
Pull the wiring plug off the top, then using a paper clip, make a U shape and connect the 2 prongs inside the wiring connector together. Put the ignition on and look at the revering lights, if they are on the wiring is all fine so the fault must be the switch.
Regards.
Martin.
dowen
Hi, remove switch, remove sealing washer and throw away, put switch back using sealing tape or past.
Worked for me! Dave.
