C5 FAP removed but
citrokid
C5 FAP removed but
Unread post by citrokid »
i had the FAP removed from the ECU and the FAP removed about 18 K miles ago, all went Ok until about 2 days ago when the mesage of risk of filter blocking came on. I have looked with lexia and cannot see anything unusal. I monitored the engine while driving and the DP cell is reading a variable pressure depending on the engine speed.
Any ideas as to what is happening would be appreciated
cachaciero
x 9
Unread post by cachaciero »
What is the pressure ? would have expected the diff pressure across the empty canister to be pretty well zero UNLESS one of the pressure lines to the diff switch is open to atmosphere.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
MikeT
x 232
Unread post by MikeT »
Could the ECU be relying on additive/tank refill counters and/or last regeneration cycle mileage?
corsehf
Unread post by corsehf »
Have you disconnected the plug from the sensor at the top of the bulkhead??
Andy
2003 C5 2.2HDi Exclusive SE Est
2001 C5 2.2HDi SX Est (gone to C5 Heaven!)
2001 Omega 2.2DTi Est (stolen by Ex!!)
1997 Xantia 2.1TD SX
1994 ZX TD Volcane
Lancia Stratos Replica
The Birdman
Unread post by The Birdman »
What size of engine is in the c5 ?
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
citrokid
cachaciero wrote:What is the pressure ? would have expected the diff pressure across the empty canister to be pretty well zero UNLESS one of the pressure lines to the diff switch is open to atmosphere.
cachaciero
the filter was punched with holes.
the Delta P at approx 70 mph at 3000 rpm was approx 11 mbar. o at tick over RPM.
citrokid
MikeT wrote:Could the ECU be relying on additive/tank refill counters and/or last regeneration cycle mileage?
counter 1 and 2 are set at 0
citrokid
corsehf wrote:Have you disconnected the plug from the sensor at the top of the bulkhead??
No because i dont know what sensor you are referring to here , can you explain please.
is it the lambda sensor ?
The engine is a 1.6 HDi fitted to a C5
The Birdman
The plug at the top is the differential pressure sensor and if your engine is the 1.6hdi and it has a combined additive and engine ecu then these sensors have to stay on , was it a simple dpf off map ,because that particular engine has been giving problems unless you change a reading at the start of the map as well as doing a dpf off.
citrokid
The Birdman wrote:The plug at the top is the differential pressure sensor and if your engine is the 1.6hdi and it has a combined additive and engine ecu then these sensors have to stay on , was it a simple dpf off map ,because that particular engine has been giving problems unless you change a reading at the start of the map as well as doing a dpf off.
It is the 1.6 HDI.
The differential pressure sensor is still connected and reading.
it was dpf off map implemented by using ECU safe ,
what is the reading at the start of the map that has to be changed ?
and how is that done ?
can ECU safe do it ?
The Birdman
I had DPF off but caused loads of regens / limp modes / white smoke , the guy who mapped it said there was i reading at the start of the map that needed to be changed because it is a combined engine/additive ecu , the ecu safe program will not get all values , i`m sorry i never paid more attention but it was a ohm value at the start that needed changing , i could get you in touch with my mapper but you would have to travel to North Antrim or send your file i would think, don`t know the cost as i got remap at same time from 110bhp to 146.3bhp.
citrokid
The Birdman wrote:I had DPF off but caused loads of regens / limp modes / white smoke , the guy who mapped it said there was i reading at the start of the map that needed to be changed because it is a combined engine/additive ecu , the ecu safe program will not get all values , i`m sorry i never paid more attention but it was a ohm value at the start that needed changing , i could get you in touch with my mapper but you would have to travel to North Antrim or send your file i would think, don`t know the cost as i got remap at same time from 110bhp to 146.3bhp.
Can you sent me a PM with an email address pls
I can send the ECU file
The Birdman
Give him a ring first to see what he recommends (Davey Wishart) you can google him to get reviews, you`ll have to make sure there are no fault codes in the file you send him i would think, he`ll also block all can fault signals for the dpf as well , theres probably nothing wrong except fault codes weren`t blocked.
Torque Tronix
131 Liminary Road
Kells
Ballymena
Co Antrim
Northern Ireland
BT42 3HZ
( 0044 (0)28 2589 8458
MOBILE: 077 3423 5815
corsehf
This sensor measures the pressure differential between the start and end of the DPF. When i had my DPF 'turned off', i was told to disconnect this sensor because although it is no longer needed, it could still be supplying useless info to the ECU and throwing it into limp home mode due to not understanding why it is receiving info for something that is no longer fitted.
Andy
1994 ZX TD Volcane
The Birdman
Depends if your additive Ecu is combined with Engine Ecu or not, 1.6hdi combined needs DPF sensor connected.
