.Would this disturbed feed give rise to tractor like noise, or have I missed a tooth on the belt. Fearing worst I have not taken it for a spin yet, though it starts on first kick!
Do AL4s have any timing reference hole for the crankshaft, I could not find one, it being an autobox assumed no flywheel so had to lock the starter ring on the gear box instead. Things were simpler on MK1, this MK2 does not even have an inspection hole on cylinder1 to check for TDC. How does one lock the cam,crank and pump accurately.
Any advice would be greatfully received. thanks
