Annoying problem, can anyone help? Changed the battery on the (97, Mk1) Xantia earlier, now I can't disable the alarm. The key plip thingy doesn't work, pressing the dashboard button with the sensor marking doesn't either (which I'm sure it did once before.)
HELP....!
Xantia alarm
- Spaces
- Location: Rarely in one place for too long - Hebridean Islands and Yorkshire are my favourites
Xantia alarm
PeterN: "Honest John's forum put the last nail in the coffin of owning a 2000- car. Many were still servicable, but CR, DMFs and needing fault codes read because your horn doesn't work - no thanks. All my life I have generally understood cars - until now."
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Hi..
Theres a Sequence for the button on the dash for it to work...
Disconnect the battery again.. have the drivers door open ready..
Reconnect the battery, and BEFORE tightening the clamp, go straight in the car, PRESS and HOLD the Alarm Cancel button FIRST and while you do switch on the ignition... the indicators should then flash and cancel it out....
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Spaces
Gracious thanks! Would have been stuffed without that.
Interested to know what not tightening the clamp's purpose could be , also does the sequence work as for "setting" the alarm , as mine never has shown signs of being set ie: No indicator flash on locking & unlockingcitroenxm wrote:Hi..
Paul
Thank's
