What is the diameter of the Rear anti roll bar bearing ? The anti roll bar diameter is 22mm ? At Citroën service site the diameter of the bearing is 22mm. I installed an 22mm bearings ( not the original but MC’s ) and the anti roll bar slips. Any one knows what is the diameter of the anti roll bar bearing ?
P.S. The bearing is the block of rubber that attaches the anti roll bar to the car’s farme
Zohar
What is the Xantia Rear anti roll bar bearing diameter ?
lancia58
- x 8
KevMayer
- x 94
KevMayer
There are 3 rear anti roll bar sizes for the Xantia without the Activa system :-
R/ANTI-ROLL BAR
96 110 217
01
DIAM 21
- INJECTION XU5JP
01
DIAM 21
- INJECTION XU7JP
01
DIAM 21
- INJECTION XU7JP4
01
DIAM 21
- INJECTION XU10J2
01
DIAM 21
- INJECTION XU10J4R SINCE RPO No. 06779
01
DIAM 21
- DIESEL XUD9
01
DIAM 21
- TURBO DIESEL XUD9TE
01
DIAM 21
- DIESEL TURBO XUD9SD
01
DIAM 21
- INJECTION XU7JB
96 110 218
01
DIAM 22
- TURBO DIESEL XUD11BTE SINCE RPO No. 07268
01
DIAM 22
- TURBO INJECTION XU10J2TE SINCE RPO No. 07268
01
DIAM 22
- INJECTION XU10J4 UNTIL RPO No. 06778
01
DIAM 22
- INJECTION ES9J4
5170 90
01
DIAM 23
- TURBO DIESEL XUD11BTE UNTIL RPO No. 07267
01
DIAM 23
- TURBO INJECTION XU10J2TE UNTIL RPO No. 07267
R/ANTI-ROLL BAR
96 110 217
01
DIAM 21
- INJECTION XU5JP
01
DIAM 21
- INJECTION XU7JP
01
DIAM 21
- INJECTION XU7JP4
01
DIAM 21
- INJECTION XU10J2
01
DIAM 21
01
DIAM 21
- DIESEL XUD9
01
DIAM 21
01
DIAM 21
01
DIAM 21
- INJECTION XU7JB
96 110 218
01
DIAM 22
01
DIAM 22
01
DIAM 22
01
DIAM 22
- INJECTION ES9J4
5170 90
01
DIAM 23
01
DIAM 23
Cheers, Kev
lancia58
- x 8
Correction : Front anti roll bar bearing diameter
Hi
Correction: I meant the front anti roll bar, I used a clipper and go that the diameter of the anti roll bar is 22.5 mm, so I installed an 22 mm bearing , I guess I need a smaller diameter bearing. The car model is 2.0 16v salon year make 2000.
Zohar
Zohar
- x 94
lancia58
- x 8
As it is now it is not only rotating but slides left and right which I assume is not the normal behaviorcitronut wrote:if you post your chassis/VIN No. i will get you price and part No. from service Citroën, specificaly for your car,
but as i said earlier the anti roll bar should be able to rotate in the bush's,
regards malcolm
Zohar
