BLOODY CITROEN DEALERSHIP!!!!!!!
- My Cars: Citroen C8
Firstly gents let me apologise for this rant put I'm very annoyed at my local dealership
I took my Xantia to the local dealership today for an LHM fluid change. Price was very reasonable, actually cheaper than a few local garages.
Picked the car up this afternoon and drove it home no problem. Been out this evening and I'm now driving around with the ((!)) & STOP icons staring me straight in the face!!! funny how this has never happened before going to the garage today!!!
I even checked the fluid and did Citroen aerobics in front of the service guy before I paid - no problems.
The car drives and stops perfectly fine so I can't understand what the issue is.
So much for been the so called 'experts'!!!!!!!
Looks like they'll be receiving a very angry phone call from me tomorrow.
Brady
Citroen C8 2.2 HDI Exclusive 2006/06
Previous French cars -
Renault Megane Tourer 2004/54 1.9 DCI Privilege
Citroen Xantia 1998/S 2.0 16v Exclusive Automatic
Renault Laguna Sports Tourer Dymanique 2001/51
Citroen Saxo VTR 2000/W
No other warning lights and I'm not sure about the float I will have to check in the daylight tomorrow.DickieG wrote:What position is the float level in on LHM tank, are any other warning lights illuminating?
Brady
Is the 'STOP' light only linked to LHM related functions?
Sounds most odd if the car is riding at normal height and stopping with no problems.
No pools of fluid under the car are there?
Colin
My cars:
1988 AX GT and still running sweet. Genuine 41 k only!!
2005 Skoda Fabia vRS 83k...and truly awesome.
Vauxhall Combo crew cab SE
Citroen Saxo 1.4 Furio.
Their cars:
Hyundai Getz.
Hyundai i20
Eriba Puck caravan now too!!
My cars:
Their cars:
Hyundai Getz.
Hyundai i20
The "STOP" light illuminates along with other lights. It will come on with the ignition and go out once the circuits see that there is no overheating, low oil pressure and sufficient LHM pressure in the system. It may also be linked to the Charging System light too.C.J. wrote:Is the 'STOP' light only linked to LHM related functions?
It could be that the Pressure switch needs looking at, but I'm no Citroen Expert... It can only be one of three switches.
B564PLC - Red/Grey Renault 11 GTL 'Premiere'
- mongoose100
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
If the fluid level is correct, that would be my next point of call too. The terminals are standard spade types which are easily opened up by ham-fisted removal. Check the tightness of fit and if suspect, pinch the females closed and re-insert.mongoose100 wrote:Plug on the top of LHM tank??? Assuming it'd light up if open circuit
I have some results -
Engine off - float is on the bottom red line
Engine running for a couple of minutes and in normal ride height - float is at the very bottom of the glass surround
In high mode - float is even lower than before
In low mode - float is at the top red line
Would this suggest Citroen haven't put enough fluid in and this is why the STOP light is coming on?
All connectors seem fine
Brady
- DickieG
- Monaco's youngest playboy
- x 38
From your description it sounds very much as if they haven't put enough LHM into the tank, possibly thinking that the float take its measurement when the car is at its normal ride height. If the stop light illuminates when the ride height position move higher than normal ride height then its all but certain that shortage of LHM is the cause.
Xantia's, XM's and the like are now very old cars in dealer terms and by now quite a number of their technicians may never have worked on Citroens using LHM, hence the reason behind the error.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
In normal ride height am I correct when i say the float should be between the two red lines?DickieG wrote:From your description it sounds very much as if they haven't put enough LHM into the tank, possibly thinking that the float take its measurement when the car is at its normal ride height. If the stop light illuminates when the ride height position move higher than normal ride height then its all but certain that shortage of LHM is the cause.
Xantia's, XM's and the like are now very old cars in dealer terms and by now quite a number of their technicians may never have worked on Citroëns using LHM, hence the reason behind the error.
Brady
Yep, basically there isn't enough fluid in the reservoir. I'd guess a non
hydraulic au fait Cit mechanic may have topped the fluid up with the car
on the normal running height and once the circuiit had stabilised not
topped it up which needs the level checked on the max/high running height.
For peace of mind if you need to use to car today I'd get another litre ot two
from the likes of Halfords if you can grit your teeth and bear paying the silly
money they charge - some GSF and EiuroCarParts open for Sunday mornings
mind. You can revisit the dealer and at the least demand they replace the
fluid you have had to add or remimburse your additional expense. How many
litres of fluid did they charge you for when they did the LHM change?
IIRC it's usually around 4-5litres.
Andrew
<<edit - I see DickieG has beaten me!>>
Andrew
Nothing moves you like a Citroën
I'm not sure how many litres they changed to be honest but I will ask when the service team call me tomorrow. I rang this morning and left a very blunt message with a member of the sales team.andmcit wrote:Yep, basically there isn't enough fluid in the reservoir. I'd guess a non
Andrew
Brady
Which one is the level warning switch?addo wrote:Leaving the level switch plug off caused me no alarms; I think it closes the circuit to set the STOP light off.
Easy to check - unplug the level switch and see if the warning ceases.
BTW, please check your driver's footwell for LHM...
Brady
