Hi, my friends 206"s, gearbox crunches loadly , while trying to get second gear and fourth gear . the other gears are ok . is the gearbox dying ?
any thoughts
cheers Terry
peugeot gearbox crunch
spider
- x 77
Does it do it at a standstill with the engine running if you select 2nd or 4th ? (use clutch obviously!)
Also try with the engine off, selecting 2nd and then 4th to 'feel' how well they go in. Compare to the other gears.
Andy.
froggy
- (Donor 2026)
- x 4
peugeot gearbox
cheers, I will let you know
Terry
Terry
