Hi
I've noticed hydraulic fluid leakage from the left side strut. I've jacked the vehicle and cleand well the strut area and found that the leak is from the hydraulic return pipe. the problem is that its friday noon now and the shops are already closed for the weekend. did anybody found a way to improvize such a pipe? is it possible to push a smaller diameter plastic pipe into the rubber pipe so that the fluid will flow through it? the leak is from the point that the pipe changes its diameter. one more question, the metal clamp that holds it can be replaced by an ordinary metal clamp, like the one that is used for water hoses? let me point that I need the improvizing only for two day, I dont intend to leave it for long time.
Thanx.
Xantia strut hydraulic return pipe - can be improvized?
atr
- x 6
- x 1240
atr
- x 6
- x 1240
citrov6
