Bulb replacement on Xantia '00
ellsy66
Unread post by ellsy66 »
I have just tried tried to replace bulbs in my Xantia using the handbook to tell me which bulbs i need (stated H7's) so went and got them tried to fit and looks like i actually needed H1's??
Does anyone know if i can actually still fit the H7's as I have heard its a better bulb anyway but can it actuall be used? There is a double fitting on the H7's but only the one on the H1's plus the hole isn't big enough to get the bulb in but i do have the option of unscrewing a part in the unit to get it in??! There does also seem to be a spare electrode that i could possible fit to the H7 actually attached to the light unit but doesn't look like it does much??
Am i being ridiculous? Please someone let me know, thanks.
x 1506
"Am i being ridiculous? Please someone let me know, thanks."
Probably...just buy some H1s and fit them, 5 minute job. H7s fit Xsaras, so someone here might take them off you if you can't take them back :lol:
Xaccers
x 188
Unread post by Xaccers »
I'm intreagued that your handbook said H7.
Going to have to dig out my Mk2 handbook and check that tonight :)
DIY sphere tool
mongoose100
Unread post by mongoose100 »
The filament will be in the wrong place, you'll have no beam pattern, possibly blinding other drivers and/or being completely useless as a form of seeing where you are going... :shock:
My advice, stick to the H1's
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
ellsy66
H1's it is then. Thanks guys
carpysmith
Unread post by carpysmith »
Hi there,
Had exactly the same problem on my mk2 xantia a few weeks back! that was after checking by usin the registration number on a suppliers website, as well as checking the handbook!! just took h7,s back to shop i got them from and swapped them for h1,s. glad i didn,t get them off the web in the end (local motor factor had a two for one offer).
Strange indeed!! glad it wasn,t just me being thick though!!!
regards Steve (aka carpysmith)
citroen xantia 2.0 hdi sx (estate)
P616VKX
Unread post by P616VKX »
I went to a Motorfactors in my town and was told that H1's and H7's fit the Xantia on a 97 plate, depending on the model. I took a H7 home and it turned out to be a bloody H1... If I'd got a H1, it'd be a H7, I just know it!!!
B564PLC - Red/Grey Renault 11 GTL 'Premiere'
