urgent help need with this part
eurotrotter
has anyone got this screw:
https://picasaweb.google.com/1096236004 ... 2068003170
http://i218.photobucket.com/albums/cc26 ... Bleed2.jpg
i have an interview for a job thursday 3 hrs south, and i cant get to my pug dealer til teh weekend
i will pay good money for one
thanks
thanks
KevMayer
eurotrotter
addo
- Sara Watson's Stalker
- x 95
eurotrotter
the fact that mine is hollow, and has a small whole in it, as seen in the this pic, could i damage the engine or cooling system by using a normal socket cap?
https://picasaweb.google.com/1096236004 ... 1697299826
addo
- x 95
No. The hole and bore exist to bleed coolant by only a slight loosening of the screw.
To bleed with a conventional capscrew you need to back it almost right out - messier and slightly less convenient, but works fine. I have a stainless capscrew in the 405 after a similar failure to yours; got the official brass one but haven't been organised enough to swap it in!
eurotrotter
- x 1240
- x 1240
eurotrotter
Xantidote
- x 5
I guess the original bleed screw won't be as strong as any replacement ordinary bolt, because the original had had the centre drilled out. Perhaps the original bleed screw was not of a very high grade/strength metal?
Martin
1995 Xantia TDLX (deceased
spider
- x 77
- x 1485
It should be M6:
1306 29
01 DRAIN SCREW
DIAM 6X100-18
- DW10 TURBO DIESEL
If it goes in without touching the sides, it has perhaps been overtightened (hence broken!) and stripped the threads in the alu housing? If you've got one that's a couple of mm too long it won't do any harm - just check it doesn't foul the thermostat.
1306 29
01 DRAIN SCREW
DIAM 6X100-18
- DW10 TURBO DIESEL
