Xantia Elec Windows power supply to switch
FuzzyEdges
Unread post by FuzzyEdges »
I've finally got around to trouble shooting my Xantia's malfunctioning front electric windows. It appears to be a broken wire in the rubber bellows between the car body and the driver's door. A degree of wiggling returns power to both windows when the door is open.
My question is which wire is the power supply to the driver's door switch?
Looking at the diagrams I think it should be wire number 600A, supplied from the relay.
If this is correct, what colour/size is it?
Many thanks.
rory_perrett
Unread post by rory_perrett »
It is a while since did this but if I remember correctly it is one of the (many) green wires and is one of the thickest in the bundle. Mine had gone almost inside the door. I needed to disconnect and undo a far amount of the wiring in the door so I could pull enough through to get at it.
Best of luck
FuzzyEdges
That's the start I need, Thanks.
