406 estate, removal of numberplate light
gaz4053
Unread post by gaz4053 »
Hi all, anyone know how to get the bulb out of the numberplate light on the tailgate of my 2001 406 estate? Had a quick look, but couldn't see an easy way. Does the inner cover have to come off first? Or can they be got at from outside?
Cheers in advance!
Gaz
spider
x 77
Unread post by spider »
From memory, the actual bulb cover comes off from the outside, you need a tiny terminal type screwdriver or similar to do it, as its easy to break the tags off.
Once its off, I think then you will see two screws or tags holding it in place.
Andy.
gaz4053
spider wrote:From memory, the actual bulb cover comes off from the outside, you need a tiny terminal type screwdriver or similar to do it, as its easy to break the tags off.
Cheers for the quick reply. I saw the two small round holes and thought the tabs would be easy to break.....quickly tried a small driver, but didn't want to force it, not knowing which way the cover came off. I've still got one working, so not desperate to sort it!!
Gaz
